Water filter
danitheplumber
danitheplumber Member Posts: 98
edited October 2016 in THE MAIN WALL
Any suggestion for economical water filter for whole house or just for boiler or water heater especially tankless?
    Steamhead Member Posts: 18,209
    What are you trying to filter out?
    Consulting
  • danitheplumber
    Mostly anything that will ruin/shorten the life of a tankless or heating unit or corrode pipes and fixtures
    Jamie Hall Member Posts: 26,844
    That's not a filter. That's a water treatment system. Filters only attack particulate material, technically. The only way to find out if you need a water treatment system is to have the water tested and then determine what -- if anything -- you need to remove. Hardness? Iron? pH problems? Manganese? All take different treatment.
  • danitheplumber
    Thought so I just remembered Dan Foley wrote an article about water treatment for tankless unit's
