Water filter
danitheplumber
Member Posts: 98
Any suggestion for economical water filter for whole house or just for boiler or water heater especially tankless?
What are you trying to filter out?All Steamed Up, Inc.
Consulting0 -
Mostly anything that will ruin/shorten the life of a tankless or heating unit or corrode pipes and fixtures0
That's not a filter. That's a water treatment system. Filters only attack particulate material, technically. The only way to find out if you need a water treatment system is to have the water tested and then determine what -- if anything -- you need to remove. Hardness? Iron? pH problems? Manganese? All take different treatment.Br. Jamie, osb
Thought so I just remembered Dan Foley wrote an article about water treatment for tankless unit's0
