Need help identifying this manifold
jeffhornby
Member Posts: 3
Hello everyone
I'm looking to identify this radiant flooring manifold
It has a leaking flow meter and I can't order the parts if I can't identify the manifold any help would be appreciated
No idea, but it wouldn't be too hard to replace it with a manufacturer well represented in your area; Rehau, Uponor, etc.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
It looks like a Viega or Uponor.
The thing that is really troubling is the amount of rust that can be seen in the flow meter.
Do you have other leaks on the system? Is the tubing O2 barrier? Is it an open or closed loop system?Bob Boan
It's not uponor
Or watts or calefi
Any one know for sure0 -
Here's a Viega from a job I was on yesterday. I've also seen Uponors that look exactly like yours.
A lot of times, manufacturers use third party vendors for their manifolds and re-brand them.
Bob Boan
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
