Need help identifying this manifold
Hello everyone
I'm looking to identify this radiant flooring manifold
It has a leaking flow meter and I can't order the parts if I can't identify the manifold any help would be appreciated
  • No idea, but it wouldn't be too hard to replace it with a manufacturer well represented in your area; Rehau, Uponor, etc.
  • Ironman
    Ironman Member Posts: 7,928
    It looks like a Viega or Uponor.
    The thing that is really troubling is the amount of rust that can be seen in the flow meter.
    Do you have other leaks on the system? Is the tubing O2 barrier? Is it an open or closed loop system?
    Bob Boan
  • jeffhornby
    jeffhornby Member Posts: 3
    It's not uponor
    Or watts or calefi
    Any one know for sure
  • Ironman
    Here's a Viega from a job I was on yesterday. I've also seen Uponors that look exactly like yours.
    A lot of times, manufacturers use third party vendors for their manifolds and re-brand them.
    Bob Boan
