Thermostat with dehumidifier control?
ChrisJ
Member Posts: 17,346
Hi all,
Like the title says, what thermostats if any can also control a dehumidifier?
I see the classic Visionpro 8000 series has a so called "dehumidification" setting but that apparently only runs air conditioning to lower humidity. I need one that will close contacts above a certain set point.
So far, the only thing I could find was the Honeywell Humidipro, but it's a separate unit.
Many will. Most of the Vision Pros, Prestige models, any of the VP and Prestige with the EIM. Ecobee3 WiFi. Might need an isolation relay.0
There's a model of the Carrier Edge Pro with dehum contacts. Curiously, I'm unaware of a Trane stat with dehum, but we aren't in as deep with them as some others.0
I found a NOS VisionPro
Never thought I'd type that....
Only thing I can't tell is if it'll allow a system to fall back to 1 stage cool after the 2nd stage has been energized. Everything else seems to work nice including the dehumidification function.
- 50 Industry Classes
