False water line
Paul S_3
Member Posts: 1,291
i have to raise my new water line about 12 inches......do you guys recommend a gifford loop or a false water line....also do i need to raise the false water line the full 4 ft as per Dans book...or just enough to mimic the old water line? thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
You can do either one, I've had no issues with mimicking the old water line1
thanks @EzzyTASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
@Hatterasguy, why would you get crucified for that? I mean who does that?
I happen to agree with you. A Vaporstat can really change things. 0 -
im using a vaporstat....and i definitely have enough height.....one pipe steamASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
I concur. Those are safe guidelites to follow, but when you have problematic systems or conditions, ya got room to play. Mad Dog0
because i dropped the original water line about 18 or so inches ....and theres a wet return that is now about 6 inches below the new water line....used to be about 2 feet below....ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
If -- and only if -- you are very careful to make sure that you know where all the wet returns are, and all the drips, and all the dry returns, and if -- and only if -- you make sure that your altered water line will not dry out anything that should be wet, or put water in anything that should be dry...
then go for it. But as our esteemed leader has been heard to say -- get out of the boiler room and check the whole system!Br. Jamie, osb
But 6 inches below the water line is still well below the water line.
No?
Oh yeah -- that's fine. I have a place out at the end of one of the longer wet returns which is only about three inches down at static water level. Works fine.ChrisJ said:But 6 inches below the water line is still well below the water line.
No?Br. Jamie, osb
so @Jamie Hall do you recommend just piping a gifford loop instead of FWL? doesnt make sense to do all the extra piping if i dont have too.....wet returns are and will be under water but not by much about 6 in or soASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
Your good Paul you don't have to pipe a gilford loop0
As @EzzyT says - your good to go as you are. Regular Hartford loop should work just fine.Br. Jamie, osb
