Copper Tubing for Steam Boilers?
Then you do not use the best material for the job. We need to quit thinking deadmen did not make choices based on price, they did. That is why they used iron for wet returns and embraced the cast iron fittings.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
What's wrong with copper on wet returns now?
hat are you a pilot0
Not sure if he is, although clearly knowledgeable. I am though, for what it's worth. Courtesy of the US Air Force...keyote said:hat are you a pilot
yes I kind of also got that you probably were as well so am I though not very active lately0
Sold my bird -- a Piper Arrow -- and don't really see well enough any more to be thoroughly safe. Sorry! But there's nothing else in the world like it!Hatterasguy said:
Unfortunately, not.keyote said:yes I kind of also got that you probably were as well so am I though not very active lately
I probably have all the book knowledge required at this point. The prospect of flying Cessna's or Pipers around the local area isn't that appealing. Now, if I had the funds for a King Air and could travel reasonable distances in comfort, safety, and style...............now you're talking.
I'll just go for a ride with Jamie.Br. Jamie, osb
Ive torn down a corvair engine that Im converting to a 130 Hp direct drive for a Zenith stol ch750 i want to build0
