Copper Tubing for Steam Boilers?
2»
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Then you do not use the best material for the job. We need to quit thinking deadmen did not make choices based on price, they did. That is why they used iron for wet returns and embraced the cast iron fittings.
    cell # 413-841-6726
    Hatterasguy
  • ChrisJ
    ChrisJ Member Posts: 17,077
    What's wrong with copper on wet returns now?
  • keyote
    keyote Member Posts: 659
    hat are you a pilot
  • ChrisJ
    keyote said:
    hat are you a pilot
    If he was the show would never get aired.
    Come on, that's funny.
    Jamie Hall Member Posts: 26,857
    keyote said:
    hat are you a pilot
    Not sure if he is, although clearly knowledgeable. I am though, for what it's worth. Courtesy of the US Air Force...
    ChrisJCharlie from wmass
  • keyote
    yes I kind of also got that you probably were as well so am I though not very active lately
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    @RayWohlfarth - Here's some more info on copper and steam systems.
    President
    HeatingHelp.com
    Unfortunately, not.
    I probably have all the book knowledge required at this point. The prospect of flying Cessna's or Pipers around the local area isn't that appealing. Now, if I had the funds for a King Air and could travel reasonable distances in comfort, safety, and style...............now you're talking.
    I'll just go for a ride with Jamie.
    Sold my bird -- a Piper Arrow -- and don't really see well enough any more to be thoroughly safe. Sorry! But there's nothing else in the world like it!
  • keyote
    Ive torn down a corvair engine that Im converting to a 130 Hp direct drive for a Zenith stol ch750 i want to build
