Radiator series loop system
Paul S_3
That never worked correctly....1/2 home depot pex used .....about 9 radiators a zone....boiler is a 167K....heat load is at worst 65K.....customer paid $XX,XXX.XX....contractor just left after he couldn't get the heat going ....notice the pump on the return (wired to come on everytime boiler fires)...and all the pumps on the supply.......3.5 million dollar home in Bedford ave in Brooklyn.....House was just renovated..i had to cut sheetrock from ceiling to floor..
.i felt bad but its the only way to get this fix....im homerunning every radiator to remote manifolds one for each floor using Viega fostapex and repiping boiler and indirect....
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
yes...this is my second one this year with similar work....i think its the same contractor.....i wish i had pics of the air conditioning work before i fixed it....i was originally called for a condensate leak from sweating ductwork.....i ran all new correctly sized and insulated ducts....the customer asked for a high efficiency boiler and they gave him this direct vent.......Oh and all circulator pumps had internal flow checks with the external B&G flo control valvesASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
plumbing and electrical work by the same contractor?Bob "hot rod" Rohr
Nice rack........
Hard on the taper Paul
@hot rod no i dont thinks so...both are butcheredASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
My eyes hurt.0
All together now
........................ 0 -
A nice thing about home running every radiator is you could potentially put a thermostat in every room. I did that in my great big Victorian. Any more than two big radiators in a loop, the water cools too fast anyway. Initially I thought I'd use the individual thermostats to lower the temp in the unused rooms, but this ended up being impractical for the most part and I saw little savings. I have all Honeywell 8000s, so what I do now is keep all the rooms at 67º. Then when I enter a room I intend to stay in for a while I can get decadent and raise the temp to 72º. With the 8000 you just push the up arrow for the new temp you want, then tell it how long you want it to remain at that new temp. When times up it will automatically revert. Easy.New England SteamWorks
newenglandsteamworks.com0 -
Finished up today...All is working well....Homerun each radiator....reverse return setup.....i know i couldve ran each loop perfectly straight....but im mobbed with calls and had to get this one done...Boiler is still oversized but system works now......
347-692-4777
ASMHVACNYC.COM
Customer did not pay enough for the original installation.....$3,500,000 divided by $99,999.99 (counting your X's to the max) is only 3.5% of the value of the house. He got a bargain and that was what the heating system was maybe worth.
Even a forced air/AC job in a track house is about easily over 5 % of the value of house. IMO
Yes, a very nice job to upgrade the "new" install.
And why should you feel bad.....I know I've been there myself on a much smaller scale for many "fix ups". It is the syndrome experienced by many tradesmen to apologize as you repair the previous knuckleheads mess.2
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
