triangle tube
Paul S_3
Member Posts: 1,288
smart 40 and 50....i just installed 2 ....im used to installing the Crown megastor indirect....how is the tank for the smart 40 and 50's drained? lets say i have to replace one there is no tank drain. thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Pump them out
To learn more about this professional, click here to visit their ad in Find A Contractor.3 -
thanks guys...ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
I've drilled a hole in the inner hx thru the lower boiler tap out of desperation when my pony pump died on site. Fun.0
Hmm.
If you pipe it like page 8 in the manual http://s3.supplyhouse.com/manuals/1297270212205/47060_PROD_FILE.pdf
Draining it is pretty easy. You hook a hose to the drain and open the drain with the supply still turned on. Once the water is flowing, you isolate the tank from the supply and house and crack the T&P. 20 minutes later, the tank is empty. It just siphons out.
I guess if some piped it incorrectly, or if you did not have a floor drain, you would need a pump or a hole or something....."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
True enough Hatt. This is a problem with the design. If you can run the hose outside or to a lower floor, you can get more of it.
Since the tube does not go all the way to the bottom of the tank, even the pump does not get it all."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
This is how I empty TT water heaters, you never get the last couple gallons
2 -
thats what i didnt do pipe a drain valve to the floor....ill do that once i start the boilers up when construction is complete....why wouldnt they just make it easy like the crown megastor's that im used to installing.....if i remember correctly some of the weil mclains are similar...this is how i drained the last weil mclain 119 gallon...thank god there was a floor drain....i guess i wasnt thinking.lol
347-692-4777
ASMHVACNYC.COM
Pretty wimpy connection to make it from the line to the install. That would be a nightmare for the tech department. Maybe something of the sort of kit that could be installed after installation. Once rough handling is done.0
Always liked the tank in tank concept, massive heating surface area, resistance to liming up. But draining, always a PIA.0
Right. Then do whatever it takes0
Or shoot it with a suitable um....device. .22, nail gun, Ramset etc.
More fun and louder!
If we are talking do whatya gotta do.
Bystanders beware.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Five shot pump riot gun would be more fun.Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge0 -
- 110 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
