triangle tube
Paul S_3
Paul S_3 Member Posts: 1,288
smart 40 and 50....i just installed 2 ....im used to installing the Crown megastor indirect....how is the tank for the smart 40 and 50's drained? lets say i have to replace one there is no tank drain. thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,569
    Pump them out
    Paul S_3Steve MinnichSWEI
  • Paul S_3
    thanks guys...
    347-692-4777
    ASMHVACNYC.COM
  • Zman
    Zman Member Posts: 7,611
    If you pipe them right, you can just siphon it. I think the manual shows it clearly. You should also use care in filling it. You must fill the DHW center before the heating side .
    Albert Einstein
    delta TJean-David Beyer
  • SWEI
    SWEI Member Posts: 7,348
    Don't forget to depressurize the outer tank before you drain the inner tank.
    Rich_49
  • Bob Bona_4
    I've drilled a hole in the inner hx thru the lower boiler tap out of desperation when my pony pump died on site. Fun.
  • Zman
    Hmm.
    If you pipe it like page 8 in the manual http://s3.supplyhouse.com/manuals/1297270212205/47060_PROD_FILE.pdf
    Draining it is pretty easy. You hook a hose to the drain and open the drain with the supply still turned on. Once the water is flowing, you isolate the tank from the supply and house and crack the T&P. 20 minutes later, the tank is empty. It just siphons out.
    I guess if some piped it incorrectly, or if you did not have a floor drain, you would need a pump or a hole or something.....
    Albert Einstein
  • Zman
    True enough Hatt. This is a problem with the design. If you can run the hose outside or to a lower floor, you can get more of it.
    Since the tube does not go all the way to the bottom of the tank, even the pump does not get it all.
    Albert Einstein
    Hatterasguy
  • R Mannino
    R Mannino Member Posts: 440
    This is how I empty TT water heaters, you never get the last couple gallons
    SWEIPaul S_3
  • Paul S_3
    edited August 2016
    thats what i didnt do pipe a drain valve to the floor....ill do that once i start the boilers up when construction is complete....why wouldnt they just make it easy like the crown megastor's that im used to installing.....if i remember correctly some of the weil mclains are similar...this is how i drained the last weil mclain 119 gallon...thank god there was a floor drain....i guess i wasnt thinking.lol
    347-692-4777
    ASMHVACNYC.COM
  • Gordy
    Gordy Member Posts: 9,546
    Pretty wimpy connection to make it from the line to the install. That would be a nightmare for the tech department. Maybe something of the sort of kit that could be installed after installation. Once rough handling is done.
  • Bob Bona_4
    Always liked the tank in tank concept, massive heating surface area, resistance to liming up. But draining, always a PIA.
  • Bob Bona_4
    Right. Then do whatever it takes :)
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Or shoot it with a suitable um....device. .22, nail gun, Ramset etc.
    More fun and louder!
    If we are talking do whatya gotta do.
    Bystanders beware.
    Taylor
  • Gordy
    After frustration a clip of .45s Would make for a quick draining. Uncontrolled but quick.
    Canucker
  • BobC
    BobC Member Posts: 5,521
    Five shot pump riot gun would be more fun.
    3PSI gauge
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,261
    edited August 2016
    With breeching loads.
    Gordy
  • Bob Bona_4
    edited August 2016
    .50 cal belt fed is what I want for some of the stuff I work on!
    Gordy
  • Gordy
    That would be fun explaining to the HO this is normal procedure.
    Bob Bona_4
  • Bob Bona_4
    That's when you need them to go up to turn up the thermostat.
    Gordy
  • Solid_Fuel_Man
    If one has not had the experience of fireing a belt fed weapon I would highly recommend of for said TT indirect ;)
    SFM
    Gordy
