3-pass steam boilers
SWEI
Member Posts: 7,348
Is the MegaSteam/FSZ the only small option still available?
Any 3-pass options offered in the 650 - 1000 ft² range?
thanks~
thanks~
Hurst makes the S45 in 8.5 BHP, though I almost hate to ask how much0
Isn't that like 285,000 btu/h?
Kinda on the large side for "small".
Looks like a nice boiler though!Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I can hear my dad already. "What do you mean can't? There is no can't. Figure out how to do it and get it done"Hatterasguy said:
That would be a real pleasure to move into a basement..................
Ditch the steam Comvert to water, and get a mod/con you can hang on the wall.......0
4 -
I'd love to. A 3-pass wet-back fire-tube with a 28" x 31" footprint? How cool is that?
To be fair, cost on the next two larger sizes is nearly the same.0 -
& everyone knows that bigger is better...0
Returning to my original question, and assuming the 5-section MST/FSZ turns out to be too small, I have come up with the following wet-base options:
Burnham V8H (362k and down)
Burnham 9A (447k and up)
Crown Series 24 (438k and up)
Slant/Fin Intrepid (434k and down)
Weil 80 series (346k and up)
I like a 4" supply, so that leaves Weil 80, Burnham 9A, and Crown. I won't use Burnham for steam (except MegaSteam), and I've never used Crown. I have done quite a few Weil 80s, and I like them. Easy choice for me.New England SteamWorks
newenglandsteamworks.com0 -
Kurt is there more room to work with then just 28"x31"?0
Oh yes. Space is not a significant concern there.
I was just impressed that someone was still making small Scotch Marine boilers. We came across one about that size on a job a couple years ago and after a bit of cleaning by the new owner it came right back to life. Natural draft, but could date from the 1950's.0
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
