3-pass steam boilers
SWEI
SWEI Member Posts: 7,348
Is the MegaSteam/FSZ the only small option still available?
Any 3-pass options offered in the 650 - 1000 ft² range?
thanks~
  • SWEI
    Hurst makes the S45 in 8.5 BHP, though I almost hate to ask how much ;)
  • ChrisJ
    ChrisJ Member Posts: 16,778
    Isn't that like 285,000 btu/h?
    Kinda on the large side for "small".
    Looks like a nice boiler though!
  • ChrisJ
    edited July 2016
    1500 lb.
    That would be a real pleasure to move into a basement.................. :s
    I can hear my dad already. "What do you mean can't? There is no can't. Figure out how to do it and get it done"
  • Gordy
    Gordy Member Posts: 9,546
    Ditch the steam Comvert to water, and get a mod/con you can hang on the wall....... :p
  • ChrisJ
    GordyratioCanuckerSteamedInWharton
  • SWEI
    This morning I asked. Roughly 9x the cost of a Slant/Fin TR-60.
  • SWEI
    edited July 2016
    I'd love to. A 3-pass wet-back fire-tube with a 28" x 31" footprint? How cool is that?
    To be fair, cost on the next two larger sizes is nearly the same.
  • ratio
    ratio Member Posts: 4,031
    & everyone knows that bigger is better...
  • SWEI
    Returning to my original question, and assuming the 5-section MST/FSZ turns out to be too small, I have come up with the following wet-base options:
    Burnham V8H (362k and down)
    Burnham 9A (447k and up)
    Crown Series 24 (438k and up)
    Slant/Fin Intrepid (434k and down)
    Weil 80 series (346k and up)
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,528
    I like a 4" supply, so that leaves Weil 80, Burnham 9A, and Crown. I won't use Burnham for steam (except MegaSteam), and I've never used Crown. I have done quite a few Weil 80s, and I like them. Easy choice for me.
    newenglandsteamworks.com
  • EzzyT
    EzzyT Member Posts: 1,367
    Kurt is there more room to work with then just 28"x31"?
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • SWEI
    Oh yes. Space is not a significant concern there.
    I was just impressed that someone was still making small Scotch Marine boilers. We came across one about that size on a job a couple years ago and after a bit of cleaning by the new owner it came right back to life. Natural draft, but could date from the 1950's.
