heat exchanger
Paul S_3
Member Posts: 1,291
oil to gas conversion coming up, existing system is an oil fired steam boiler with a tankless coil. I would like to use an indirect with a brazed plated heat exchanger. I have done these multiple times before but a few times before I had a call back due too the brazed plated heat exchanger clogging up on the boiler side. should i pipe a Dirtmag before the heat exchanger....would you guys use a storage tank with a tankless coil instead?? or another type of heat exchanger. Everhot? I cant seem to find a distributor for them. i want to provide the most reliable system i can....thanks
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
would a stainless steel indirect be ok like the crown megastor?...I know the htp superstor has a cupronickel heat exch...should i use a dirtmag before the pump?ASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
A Megastor would be great.
As to the dirt mag... That is going to need a lot of maintenance.
I think you would be better off spending the money on a 3 pc. circulator like a Taco series 110 or a B&G series 100. They can handle the harsh environment of all that muddy water.
Some would even suggest a bronze version of those but that is huge $$.0 -
Paul Sid Harveys is the Everhot heat exchanger distributor1
thank you @EzzyT .....i will call themASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
- 167 Indoor-Air Quality
