heat exchanger
Paul S_3
Paul S_3 Member Posts: 1,291
edited July 2016 in THE MAIN WALL
oil to gas conversion coming up, existing system is an oil fired steam boiler with a tankless coil. I would like to use an indirect with a brazed plated heat exchanger. I have done these multiple times before but a few times before I had a call back due too the brazed plated heat exchanger clogging up on the boiler side. should i pipe a Dirtmag before the heat exchanger....would you guys use a storage tank with a tankless coil instead?? or another type of heat exchanger. Everhot? I cant seem to find a distributor for them. i want to provide the most reliable system i can....thanks
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • kcopp
    kcopp Member Posts: 4,630
    I would not do the BP HX for the reasons you mentioned... and the added cost.
    I would get a good quality coil type Indirect and pump through that. Passages are wide open.
    It will have to be a version that is Non Ferrous....
    Superstor Ultra or Superstor Pro are two options.
    Zman
  • Paul S_3
    edited July 2016
    would a stainless steel indirect be ok like the crown megastor?...I know the htp superstor has a cupronickel heat exch...should i use a dirtmag before the pump?
    347-692-4777
    ASMHVACNYC.COM
  • kcopp
    A Megastor would be great.
    As to the dirt mag... That is going to need a lot of maintenance.
    I think you would be better off spending the money on a 3 pc. circulator like a Taco series 110 or a B&G series 100. They can handle the harsh environment of all that muddy water.
    Some would even suggest a bronze version of those but that is huge $$.
  • EzzyT
    EzzyT Member Posts: 1,378
    Paul Sid Harveys is the Everhot heat exchanger distributor
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Paul S_3
  • Paul S_3
    thank you @EzzyT .....i will call them
    347-692-4777
    ASMHVACNYC.COM
