Is this good near boiler piping
keyote
keyote Member Posts: 659
Excuse the hand drawn near boiler sketch dont have a good program for that yet, and i realize lots of bells and whistles missing but am trying to figure out best basic design first. also include the loop views of the zones i did in loop cad but put the totals on boiler plan. I have an extra TT indirect tank and thought to ad solar in future as well as another zone on a fith floor PH addition so all risers are 1" copper.
  • keyote
    hears anoth version of the near boiler
  • keyote
    I dont think this second version materially differs from the first except the secondary is closed in a way which i suppose makes the zones technically tertiary. space is tight down there would it matter and BTW i imagine the secondary ch pump is an alpha
  • Ironman
    Ironman Member Posts: 7,918
    Take the return from the indirect and tee it back into the primary return at the boiler, not into the secondary. Use check valves with each pump.
    Bob Boan
  • keyote
    i understand youd rather see it hit the return downstream of the ch return tee. Turbulence?
  • Ironman
    Hydraulic interference. Your defeating the purpose of p/s with it connected to the secondary.
    Bob Boan
    Gordy
  • keyote
    edited July 2016
    Thanks
    I corrected the drawings with the idhw return tee downstream of the ch return tee and added check valves, i know theres all sorts of things like separators strainers draincocks close tees and valves etc etc etc not shown yet. but would it matter which version of these two? i show one with the secondary loop closed excluding the zones and the other with the zones being part of the secondary loop is that important
  • keyote
    edited July 2016
    i dont think the attachments are attaching
