Gov't intervention in boiler selection
Remember that the condensing gas furnaces are rated AFUE 90+.
Add to that the fact that most need a communicating system mated user interface ( the customer thinks it's a thermostat) to reach full potential and a lot of contractors don't install them, they use standard thermostats that greatly reduce these units efficiencies and disable the variable speed function.0 -
I spend around $1800 in gas per year, for heat, water, clothes dryer, gas grill.GreenGene said:I've noticed a lot of the gas vs oil calculators originate from gas companies and the excel program seems a little skewed.
Wish I could find that old data, last time I got oil I paid $1.60, it blows gas out of the water, checking their conversion excel programs shows they have oil set at $3 or higher, the oil equipment at very low eff and the gas at very high. If I refactor the program properly they come out close to even, hmm.
Fact is if you're going to convert it's going to take 8-20 years to pay you back, THEN you start saving.
With oil you can always get heat with any diesel based fluid, even veggie oil if needed, with gas?
If the unit is due for replacement they'd have to spend the money anyway so if they were on the line it could be justified but to do it just to save money isn't realistic because you aren't going to for years.
My neighbor, similar sized house and construction, was spending a little over $5000 a year in oil. He owned a duplex, one side hot water, one side steam, both were similar in consumption and he kept his temp at 65F, mine is at 72F. This was back when oil was around $3.20-3.50 a gallon.
No, oil doesn't blow gas out of the water. EVER.
No, the calculators aren't skewed.
"With oil you can always get heat with any diesel based fluid, even veggie oil if needed, with gas?" Well.................since I never run out................not sure how to respond to this? I suppose in an absolute emergency where somehow, there is no natural gas, I'd use my oil filled electric radiators. Same thing I've done in the past if something were to fail.
That said, I've been considering converting my gasoline generator to NG because the chances of NG being lost vs everything else is very, very slim.
and I have a 2003 Sanyo 31 tube tv that draws 89 watts
I have a larger flat screen think it's 42", hmm, it has a rating on the back of 3 amps
Pf x V x A = W no? est 320 watts
BUT old tvs do use more power when idle than the new ones0 -
Older LCDs had CCF backlights that drew much more power (and they fade as they age.) Newer designs are based almost exclusively on LED backlights which draw a LOT less power.0
32" led back-lit LCD smart TV power consumption 27.95w
Besides the cost per BTU difference- which varies as prices rise and fall- oil suffers from tank and other leaks, faulty deliveries causing customers to run out of oil and servicing issues such as failure to properly maintain customers' equipment. A lot of people switch to gas to get rid of these issues.ChrisJ said:
That said, I've been considering converting my gasoline generator to NG because the chances of NG being lost vs everything else is very, very slim.All Steamed Up, Inc.
Consulting2 -
Agree, people should change their refrigerators every 5-10 years.
We just got a new Samsung with the DIC and a 10 year warranty, the next choice was the LG Linear.
Amazingly quiet.0 -
Do to tax credits and rebates we see a lot of Areco boilers in schools and other government type buildings.0
null
I have a 16 month old $3K LG..... and warm beer!To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Warm beer is never good in any situation. Lol0
Since you asked, they are good for business but I'm not quite sure why the government and utilities should incentivize certain behaviorChrisJ said:
There's plenty, no need to make them up!Stephen Minnich said:Incentivize? I had to look that up. I thought you were making up words.
You don't need a calculator to figure out the price per therm of oil or gas, Doing so eliminates all "smoke and mirrors". I got sick and tired of being held captive to the whims of some middle eastern sheiks. If you locked in at a fixed price for oil, for the season, you paid higher than everyone else. And, invariably, that would be the season that the price didn't go up. If you rolled the dice and didn't lock in, the price would quadruple by peak heating season. To the sheiks.......Stick your oil where the sun don't shine!0
Um. Well. Maybe. Except in New England, the funny thing is that on the very cold days, when you really want to be warm, the gas flow isn't sufficient and the pressure drops, system wide. And sometimes the NG stuff works, and sometimes it doesn't. This isn't going to get fixed anytime soon, either.ChrisJ said:
On the other hand, you don't have to worry about plowing the barnyard so the heating truck can get in to fill the tank. The greenies fixed that one, too -- we were forced by the State to remove our 3,000 gallon tank some years back...
Can't win.
@Jamie Hall
I've only heard that coming from the Boston area. I'm sure others will weigh in, but we don't have any problem with gas pressure.0 -
Who needs gas when we got heat pumps lol0
Ah,
I see @GreenGene is handing out dislikes now.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
What else would Robert? Especially if the consumer is informed of the dirty secret about how certain HE products that don't come close to their rated efficiency unless subject to specific conditions sure will not.0
It always better to use someone else's money especially when sanctioned by the government.Robert O'Brien said:So rebates and tax credits paid for by the public are OK to sway consumers decision making?
Like any rebate program, does it benefit the public more than it burdens them.R Mannino said:
Would the advantages of knowing that information, or having access to the funds for example lessen fuel consumption, make more fuel available to customers at a lower cost, assure adequate supplies at high demand, reduce potential spills. eliminate leaking oil tanks. If so I would vote in favor of the program, although i would like to see all the details, and where the funding was coming from, like lottery ticket sales?
I think all those questions should enter into any decision to make rebates and incentives available. We certainly subsidize all the other fuels and energy, and maybe some of that $$ ends up in the CEO pocket?
Living the hydronic dream1 -
In the seventies Canadian government helped fund installing energy recuperators on boilers for research. A conclusion whether investment pays was never reached as far as I know.0
All that works just fine until the money runs out. The stuff is not an infinite resource...R Mannino said:
A further general and somewhat philosophical comment -- the various rebate and incentive programs are fine -- for the people who can benefit from them. For the remainder of the poor slobs, they are a burden, either in the form of higher utility rates, fuel prices, or taxes. The ain't no free lunch.Br. Jamie, osb
If a technology can't sell itself then we should not subsidise it. For r&d however, there have been many good things come from gov't funded wood burning appliances. But their sales are not subsidized, but are mandated in most states. The consumer gets a truly more efficient design and the neighbor gets less particulate pollution.
It certainly is a two-edged sword though, it's like all those Phillip Morris adds about quitting smoking.
SFMServing Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
Sheiks? that's propaganda, Bush& Cheney and others control our oil from the ME, most of our oil comes from Canada, Bush, Cheney et al have business deals in the ME going way back, look up Kuwait-American corp, KBR, Halliburton, most all did business with and in Iran during crises and bans, it's business, all of Iraq's oil went to China, that's why we invaded Iraq.Paul48 said:You don't need a calculator to figure out the price per therm of oil or gas, Doing so eliminates all "smoke and mirrors". I got sick and tired of being held captive to the whims of some middle eastern sheiks. If you locked in at a fixed price for oil, for the season, you paid higher than everyone else. And, invariably, that would be the season that the price didn't go up. If you rolled the dice and didn't lock in, the price would quadruple by peak heating season. To the sheiks.......Stick your oil where the sun don't shine!
Try to put it in perspective and forget what our media has told us, how would you like it if since WWII other nations were here in the US taking our coal and oil and gas, taking all the profit and if they gave us work it would be menial and at low rates?
Look up and read about the 1953 Iranian Coup D'etat.
We and the Brits set up shop there after WWII, built US like towns for US and Brit workers paid them high, segregated the Iranians and paid them next to nothing, their Prime Minister, democratically elected I might ad, declared all of Iran's oil sovereign and owned by the people.
We staged street riots and propaganda, a tactic we still use, and put our puppet the Shah in power.
It was the catalyst for all of our problems.1 -
problem is the consumer can still buy junk, I tried to educate my state govt about outdoor wood boilers and how design affects the burn, my argument was to not allow anything that wasn't gasification or had a good quality chamber that heated the wood, any wood boiler that has no chamber will smoke like a green wood fire because the water will constantly suck the heat out of it.Solid_Fuel_Man said:If a technology can't sell itself then we should not subsidise it. For r&d however, there have been many good things come from gov't funded wood burning appliances. But their sales are not subsidized, but are mandated in most states. The consumer gets a truly more efficient design and the neighbor gets less particulate pollution.
SFM
but then again, I live in Corrupticut and all you have to do is slip any of our politicians a beer and $44 and they'll do anything.
They did pass a regulation that it's stack had to be as high as any stack with a few hundred feet and higher than any building within that...woopy, still stinks and smokes out the neighborhood.0 -
I don't agree with subsidiaries on manufactured equipment for the general public. I would agree with shifting tax burdens and extraction fees in such a way that it would naturally persuade the public to shift to an energy source that is the most sustainable, environmental and economical for our country.0
Who decides what fuel meets those qualifications?Harvey Ramer said:I don't agree with subsidiaries on manufactured equipment for the general public. I would agree with shifting tax burdens and extraction fees in such a way that it would naturally persuade the public to shift to an energy source that is the most sustainable, environmental and economical for our country.
Politicians will decide.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Yes that's probably true. And it's up to us to try and get the right politicians in the right places. A daunting task.0
Is there such a thing? It seems like frog's hair these days. When they do come along, people get scared or are made scared by one side or the other. I vote against ALL incumbents as a matter of principal. Turn over the congress and senate a couple times and they wake up and realize who is in charge. I can't get more than 2 people to carpool at work so getting the whole nation together I have deemed impossible at this point, but I keep talking anyway.Harvey Ramer said:Yes that's probably true. And it's up to us to try and get the right politicians in the right places. A daunting task.
How is that been working out so far?Harvey Ramer said:Yes that's probably true. And it's up to us to try and get the right politicians in the right places. A daunting task.
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 969 Plumbing
- 385 Solar
