Free 55 EDR radiator
BobC
Member Posts: 5,539
There is a 38" high 11 section radiator free for the taking across the street from me. It was on a hot water system so It's good for hot water or steam.
It's on Edwin St in N Quincy, MA at 11AM; if you want it don't delay because a scrap scavenger will snap it up if he finds it
3PSI gauge
3PSI gauge
What the crap Bob why are you ripping radiators out!.BobC said:There is a 38" high 11 section radiator free for the taking
across the street from me.It was on a hot water system so It's good for hot water or steam.
And when did you switch to that evil hot water system?BobC said:There is a 38" high 11 section radiator free for the taking. It was on a hot water system so It's good for hot water or steam.
That house was gutted last year and they replaced the old snowman with a new modcon and baseboards - at least it wasn't FHA.
The other rad was taken away when the house was done over, this one was removed about a decade ago because the old owner did not want heat in her bedroom. It been in the cellar since then, I'm just glad i wasn't involved in moving it.
I just figured I'd rather see it get used than scrapped.
3PSI gauge1 -
Hot water systems ROCK!Steve Minnich0
Radiator is gone, hopefully to someone who will use it.
3PSI gauge0
