Free 55 EDR radiator
BobC
Member Posts: 5,478
There is a 38" high 11 section radiator free for the taking across the street from me. It was on a hot water system so It's good for hot water or steam.
It's on Edwin St in N Quincy, MA at 11AM; if you want it don't delay because a scrap scavenger will snap it up if he finds it
3PSI gauge
3PSI gauge
What the crap Bob why are you ripping radiators out!.BobC said:There is a 38" high 11 section radiator free for the taking
across the street from me.It was on a hot water system so It's good for hot water or steam.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
And when did you switch to that evil hot water system?BobC said:There is a 38" high 11 section radiator free for the taking. It was on a hot water system so It's good for hot water or steam.
That house was gutted last year and they replaced the old snowman with a new modcon and baseboards - at least it wasn't FHA.
The other rad was taken away when the house was done over, this one was removed about a decade ago because the old owner did not want heat in her bedroom. It been in the cellar since then, I'm just glad i wasn't involved in moving it.
I just figured I'd rather see it get used than scrapped.
3PSI gauge1 -
Hot water systems ROCK!Steve Minnich0
Radiator is gone, hopefully to someone who will use it.
3PSI gauge0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
