A bit about vacuum pumps
HeatingHelp
HeatingHelp Administrator Posts: 706
edited May 2016 in THE MAIN WALL
imageA bit about vacuum pumps
He wanted to take advantage of the 1,700:1 expansion ratio between water and steam. The trick was to make all the pipe joints tight so that air couldn’t get back into the system once the steam had shoved the air out, and to use special air vents that had check valves at the outlets.
Read the full story here
  • robglo
    robglo Member Posts: 1
    very good
  • jumper
    jumper Member Posts: 2,458
    Before heating season begins,it's a good idea to pump down as low as you can.Air is never good for steam heating.
