Looking for High Wall ductless unit without invertor
The Steam Whisperer
Member Posts: 1,315
Application is a church sanctuary where the unit will run full load whenever it is on, since it will be either cooling down the space or "undersized" when the space is occupied. I find just a small amount of cooling for church sanctuaries does wonders for comfort since the space is only occupied for a short period of time and precooling can be used. I am looking for the largest quality unit I can find, since noise is a major issue ( the heat is steam, so quiet is the norm for the space). The only one I have been able to find is the 3 ton Toshiba/Carrier Comfort unit with a simple rotary compressor...thier bottom line residential unit. With an EER of 13, IIRC, it probably matches or outperforms most invertor units at full load. Any others out there......
www.mitsubishielectric.com
I find them to be incredibly quiet..have installed a lot0 -
I think Gree might make them as well.0
Heat Controller D series
@John Mills is correct heat controller d series is non inverter ....there ok units seem well made....I just installed about 12 engineer specd them on a jobASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
I couldn't find the non-invertors on Mitsu's website...which model are they. Also, looked at heat controller and they top out at 2 ton...hope to go bigger. Also, looked at Grees they all look like invertor units.
Thanks for the input, all>
I need to keep looking....To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Maybe EMI,(Utica Boilers) out of Rome,NY.?
