Gas Line Welding Colorado
Zman
Member Posts: 7,611
Does anyone have a recommendation for a gas line welding contractor in Colorado.
I have a job requiring about 400' of 6" pipe both above and below ground. The system will have a handful of sub meter manifolds along the way.
Thank in advance.
Carl
Thank in advance.
Carl
Albert Einstein
Albert Einstein
Contact Pipefitters local 208 Denver CO. they should be able to direct you to a good contractor
For the underground part, can you use polyethylene? You've got to bury it deeper than steel and attach a copper tracer wire along with it, but it sure is easier to install. And it will probably last longer than steel as well.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
