A bit about vacuum pumps
HeatingHelp
Administrator Posts: 718
He wanted to take advantage of the 1,700:1 expansion ratio between water and steam. The trick was to make all the pipe joints tight so that air couldn’t get back into the system once the steam had shoved the air out, and to use special air vents that had check valves at the outlets.
very good0
Before heating season begins,it's a good idea to pump down as low as you can.Air is never good for steam heating.0
- 167 Indoor-Air Quality
