Replacement for HB Smith 340
replacementneeded
replacementneeded Member Posts: 2
edited May 2016 in THE MAIN WALL
I have a boiler - HB Smith 340 Mills 11 section old boiler. When i called HB Smith, they told me it was 1.392 million btu. I'm willing to replace it but im not sure if A.O. Smith 28HES5 (5 section) will be enough. Advice needed
Thank you
  • John Mills_5
    John Mills_5 Member Posts: 952
    First thing to do is say where you are. Maybe there's a pro on here in your area that can quote you. Otherwise, tell more about the system. Steam, hot water, type of building?
  • replacementneeded
    Type of System: Steam and Hot Water
    Type of Building: Brick
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,593
    edited May 2016
    The old boiler is irrelevant. Steam boilers need to be sized based on connected radiation and water boilers need to be sized based on heat loss.
    SWEI
