Replacement for HB Smith 340
replacementneeded
Member Posts: 2
I have a boiler - HB Smith 340 Mills 11 section old boiler. When i called HB Smith, they told me it was 1.392 million btu. I'm willing to replace it but im not sure if A.O. Smith 28HES5 (5 section) will be enough. Advice needed
Thank you
Thank you
First thing to do is say where you are. Maybe there's a pro on here in your area that can quote you. Otherwise, tell more about the system. Steam, hot water, type of building?0
Type of System: Steam and Hot Water
Type of Building: Brick0 -
