Coupling for steam pipe?
I'm looking for something simple.
You can clean up the area of a pinhole leak, and put a pipe clamp with rubber gasket over it. This will buy time, but is not a permanent repair.--NBC0
How big is the pipe? If 2" or less, relatively simple for a contractor to cut out the bad section, re-thread, and reconnect. More complicated if the pipe is larger than 2". Why don't you send us a picture?New England SteamWorks
newenglandsteamworks.com0 -
Viega MegaPress is approved for low pressure steam.0
I'd love to know how well the Megapress holds up over 20 years or so, I guess I'll have to wait and see.
3PSI gauge0 -
How do you stop a steam pipe from moving laterally?
One of these had been installed on 1" steam line in my house before I bought it. It worked fine for about 8 years before it started leaking. Fortunately, it was in readily accessible part of the basement.RJ said:dresser coupling
Lesson learned: re-pipe with a threaded connection.
Easily done with a pipe cutter, some threading oil and a ratcheting manual threader.
Even easier with a power threader if you're lucky enough to own one.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
A Swiss company sells very expensive clamps that is supposed to work under far more challenging conditions than low pressure steam.0
How about a Baker coupling? Grease the compression rings and don't over tighten. Will that allow movement from thermal cycles? Steam is miniscule pressure.0
isn't a baker same as a dresser? just different companies.0
All sounds like bandaids that will fail in the neat future.
What's so hard about threading a pipe in place these days!? If it's not a shark bite or pex people throw a fit.
We still don't know the size of the pipe do we?
I have a customer with a no longer needed 3 1/2" steam main (still connected to header) that is seeping on the bottom. If they needed to keep it then a welder would be the only solution. I have advised them to get the welder in the spring and cut and cap it off. Not a thread in place item
. 0 -
Think about all of those steam mains and run outs that were all threaded by hand.JUGHNE said:We still don't know the size of the pipe do we?
2", 3" etc.
Welding I suppose is fine too, but like threading it's a skill.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Why not use a union ? Pretty simple if you are replacing a section.0
I think about someone with really big arms everytime I look at 3 to 4" threaded pipe that was installed in 1915 before electricity was even in this town..........but this was done standing on the ground with a good pipe vise. Not on an 8' stepladder as some repairs might require. Is 3 1/2" threader and fittings common, just curious.0
@JUGHNE
But all in all, you know my meme is still correct regarding modern plumbers.
I shouldn't even say "modern"
Young plumbers......
Guys only using pex and who would actually use a shark bite on a job.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Yes, refusing to use any type of PEX for H & C supplies has helped to ease me out of most of the plumbing work.....copper sweat or black pipe work only is pretty well all I do in that trade.0
I don't know how common, but I'm guessing not very. I have a 3 1/2" main and my plumbing supply store was THRILLED to sell me a 4" to 3.5" T fitting. They said they had 2 left and hadn't sold one in about 10 years. I almost bought the other "just in case".JUGHNE said:I think about someone with really big arms everytime I look at 3 to 4" threaded pipe that was installed in 1915 before electricity was even in this town..........but this was done standing on the ground with a good pipe vise. Not on an 8' stepladder as some repairs might require. Is 3 1/2" threader and fittings common, just curious.
@ChrisJ , I had a terrible time finding a compression fitting when I recently changed out the broken fixture in my old claw foot tub. I finally found one at my old faithful old-fashioned supply store. Every other plumbing supply ONLY sold shark bite fittings.
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0
