Hot-water zone off a steam boiler
BergenTodd
Member Posts: 2
I read the following article regarding building a hot water zone off a steam boiler using a heat exchanger with interest.
https://heatinghelp.com/systems-help-center/how-to-run-a-hot-water-zone-off-a-steam-boiler/
However, I cannot find a plumber in north NJ who appears to be familiar with this kind of setup. Any idea where I can find a suitable plumber?
@BergenTodd I'm located in northern nj you can sent me a private message1
@EzzyT I'm sorry, for some reason I was thinking you were South NJ.EzzyT said:@BergenTodd I'm located in northern nj you can sent me a private message
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
This is the OP.
Thank you for everyone who replied.
I got in touch with someone who should be able to work on the system. I'll be back if I need any more help.
Thanks!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
