What are these??
Ross_24
Ross_24 Member Posts: 82
These are on an old oil-fired, hydronic system. They have me stumped. What are they?
Seem to be something for expansion but they have coin vents on the end of the pig tail which makes me think air elimination.
Dan Foley
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,853
    I think it is an early style of water hammer arrestor. The vent is not to let air out, but to let air in, which is compressible. The spring design, theoretically, will absorb any hydraulic shock caused by quick closing solenoid valves (dish washer, clothes washers ice machines, etc). They are normally connected to the potable water system,and not the closed loop hydronic system.
    ME
  • Ross_24
    ME
    Thanks, Mark! It's very odd, because this is the second home lately where I've seen these on the hydronic system not the domestic.
  • ChrisJ
    ChrisJ Member Posts: 15,767
    Perhaps they are being used for thermal expansion instead of a single compression tank?
    Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,541
    ME
    Correct, quite common around here. The vent is for draining them as they fill with water over time
  • Mark Eatherton
    ME
    Strange Ross... Can't really see it doing any good on a hydronic system unless there was hammering, like when happens with Honeywell valves are installed backwards... The applications I've seen were domestic.
    ME
  • Ironman
    Ironman Member Posts: 7,377
    The remnants of Grandpa's still?
    Bob Boan
  • Mark Eatherton
    Now THAT would really mess with the PONPC. I've seen jobs that had two expansion tanks on it. One in the basement near the mechanical package and one in the attic. The pumps kept switching between positive and negative discharge. I eliminated the tank in the attic and pumps started working as they were supposed to, providing all positive pressure differential.
    I seriously doubt that these devices would react much with a slow pressure increase, as opposed to stoping mechanically induced water hammer.
    ME
  • ChrisJ
    ME
    Well, they do allow room to expand without pipes bursting, so I donno?
