What are these??
Seem to be something for expansion but they have coin vents on the end of the pig tail which makes me think air elimination.
I think it is an early style of water hammer arrestor. The vent is not to let air out, but to let air in, which is compressible. The spring design, theoretically, will absorb any hydraulic shock caused by quick closing solenoid valves (dish washer, clothes washers ice machines, etc). They are normally connected to the potable water system,and not the closed loop hydronic system.
METhere was an error rendering this rich post.
Thanks, Mark! It's very odd, because this is the second home lately where I've seen these on the hydronic system not the domestic.Mark Eatherton said:I think it is an early style of water hammer arrestor. The vent is not to let air out, but to let air in, which is compressible. The spring design, theoretically, will absorb any hydraulic shock caused by quick closing solenoid valves (dish washer, clothes washers ice machines, etc). They are normally connected to the potable water system,and not the closed loop hydronic system.
ME0 -
Perhaps they are being used for thermal expansion instead of a single compression tank?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
Correct, quite common around here. The vent is for draining them as they fill with water over timeMark Eatherton said:I think it is an early style of water hammer arrestor. The vent is not to let air out, but to let air in, which is compressible. The spring design, theoretically, will absorb any hydraulic shock caused by quick closing solenoid valves (dish washer, clothes washers ice machines, etc). They are normally connected to the potable water system,and not the closed loop hydronic system.
ME
To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Strange Ross... Can't really see it doing any good on a hydronic system unless there was hammering, like when happens with Honeywell valves are installed backwards... The applications I've seen were domestic.Ross said:
ME
ME
The remnants of Grandpa's still?Bob Boan
Now THAT would really mess with the PONPC. I've seen jobs that had two expansion tanks on it. One in the basement near the mechanical package and one in the attic. The pumps kept switching between positive and negative discharge. I eliminated the tank in the attic and pumps started working as they were supposed to, providing all positive pressure differential.
I seriously doubt that these devices would react much with a slow pressure increase, as opposed to stoping mechanically induced water hammer.
Well, they do allow room to expand without pipes bursting, so I donno?Mark Eatherton said:ChrisJ said:Perhaps they are being used for thermal expansion instead of a single compression tank?
MESingle pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
- 85.7K THE MAIN WALL
- 50 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
