Need to replace wiring - what kind to get?
marcusjh
Member Posts: 84
So, this has been like this for awhile. It goes down to the box on the blower motor- not sure whether this is special wiring, or not... can someone help? Thanks-
It's probably fine, looks like just the cloth sheath is torn but the wires look fine. It's your low voltage thermostat wiring. If you want to replace it get 18 gauge 2 wire thermostat wire. HD or lowes sells it.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
For residential use, MC cable is fine.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Yeah,
I don't see anything wrong with the actual insulation.
I used 18-4 Belden wire for mine, but only because it's what I was able to get easily and cheap. If that was mine I'd leave it alone though.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Could you post a picture of where they connect on the "blower motor"......I'm guessing the oil burner??0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
