Need to replace wiring - what kind to get?
So, this has been like this for awhile. It goes down to the box on the blower motor- not sure whether this is special wiring, or not... can someone help? Thanks-
Welcome
It looks like you're new here. Sign in or register to get started.
  • Dave0176
    Dave0176 Member Posts: 1,178
    It's probably fine, looks like just the cloth sheath is torn but the wires look fine. It's your low voltage thermostat wiring. If you want to replace it get 18 gauge 2 wire thermostat wire. HD or lowes sells it.
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
    ChrisJ
  • For residential use, MC cable is fine.
  • ChrisJ
    ChrisJ Member Posts: 16,714
    Yeah,
    I don't see anything wrong with the actual insulation.
    I used 18-4 Belden wire for mine, but only because it's what I was able to get easily and cheap. If that was mine I'd leave it alone though.
  • JUGHNE
    JUGHNE Member Posts: 11,416
    Could you post a picture of where they connect on the "blower motor"......I'm guessing the oil burner??
Welcome
Welcome
