Broken piece
MissB
Member Posts: 39
Tonight we did updates on the boiler. Everything seemed good until we noticed a leak in the up pipe from the low water cut off. When we removed the small up pipe, it broke due to corrosion. We went to Lowes because the supply store was closed. At lowes we pieces together copper pipe and 3/8 fittings. We bent the pipe into the same shape as the old up pipe. Filled and fired the boiler. As soon as steam comes up, leaks ....
So now we have no heat.
Did you use ferrules?0
and Never Seize?Danny Scully said:Did you use ferrules?
Or flare the tubing?Danny Scully said:Did you use ferrules?
Peter Owens
SteamIQ0 -
I just bought the replacement part. However, it bends at a 90 ... not the angle we need.0
If you get a new LWCO of the same type, it will come with all the connecting pieces.--NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
