Triangle Tube Solo 110 Ignition Trouble
Jarno7
Member Posts: 3
in Gas Heating
Our boiler is a Triangle Tube PT110 LP. It is one year old. I am concerned about the way it ignites. When the thermostat calls for heat, the blower starts, and after a few seconds a noticible “puff” sound, followed in about 10-15 seconds by a rather loud “slam”. At this point the display will usually show the flame signal, if not, in a few more seconds, it will ignite with another, softer “slam”, after which the flame signal appears, boiler temperature climbs, and things appear to be operating normally. The venting is through the roof of a one story ranch, about 25 feet of pipe and (5) 90 degree elbows on each leg. Exit through the roof is via a co-linear adapter. Looking at the stack, vapor seems to be rising normally. This behavior seems to have started just recently, when it was first installed it seemed almost silent when starting up, even when standing right next to it.
I'd like to know what's going on.
Ideally, I would like to have an diagnostician with experience with the setup of these boilers take a look at it. The original installers did not attempt to optimize it’s performance, and there are possibly other things that can be corrected or improved. We are located in Fairfield County, CT.
Could be the igniter. They've changed the design due to these types of issues. Suggest you get a contractor.
I too have a TT 110 and have the same issues as you. The loud slam after startup. Not sure what is even making it. I have a new ignitor on hand ready to change due to failed ignitions once in a while. That is on my list for this spring and a good cleaning and combustion test.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
