Steam from the Sun
Steamhead
Member Posts: 17,710
This is interesting- bet it could be scaled down to district-steam size:
http://www.dailykos.com/story/2015/12/17/1461055/-Now-THAT-S-how-you-do-solar-energy?detail=email
Consulting
Consulting
1
Too bad that these systems attract insects which in turn attract birds which in turn creates "streakers". Look it up0
Yeah, now were talking. Nice find.
I did see some residential sized trough collectors intended to generate fluid temperatures to drive absorption chillers for AC. Heat and AC from solar thermal, makes the ROI much more attractive.Bob "hot rod" Rohr
It makes a lot of sense in areas with plenty of sun and open land. You would need a crew to kep the mirrors clean.
3PSI gauge0 -
A couple month ago, I was reading about a company that was building concentrated solar generators that were sized for residential use. They used a parabolic mirror to focus the suns rays at a Stirling motor/generator. It made 3kw of power, and the temperature at the focal point was 700*, so they got hot water off it for heating. Because it generated power, it was able to track the sun by itself. I got the impression that "big business" was doing their best to put them out of business.0
There was actually a device in the early 20th Century called a Heliostat. It was installed at the top of a tall building over a shaft going all the way to the basement. It had a huge mirror which could track the sun and reflect light down the shaft, where smaller mirrors would grab some of the light and distribute it to the rooms. If there was no sunlight, auxiliary electric lights were used. Some versions had devices which cleaned the mirror automatically.
When was the last time any of us saw a Heliostat?All Steamed Up, Inc.
Consulting0 -
I think ME has talked about a heliostat at NREL in Colorado?Bob "hot rod" Rohr
Here's the one I read about a long time ago- patent granted in 1938:
http://www.freepatentsonline.com/2135997.htmlAll Steamed Up, Inc.
Consulting0 -
We really need to re-visit the thinking that made that. We sit in our houses on beautiful, sunny days, and have electric lights on. The same interests that kept Tesla from giving power to humanity, for free, are preventing the advancement of technologies they can't profit from.0
Just so long as the mirror thingy can work as an umbrella I'm fine with it. On the long term average where I live we get three hours of sunshine per day, averaged over a year.Br. Jamie, osb
High up on Table Mesa in Golden Colorado, SIggy and I were getting a back alley tour, and they took us to their "Accelerated Solar Exposure Lab", where they have a sizable heliostat. They had just gotten done melting a brick for a group of young students when we walked into the lab. Stunk to high heaven.hot rod said:I think ME has talked about a heliostat at NREL in Colorado?
Unfortunately, solar PV is considered far more sexy because it can spin the meter backwards, and solar thermal is taking a back seat to the PV technology.
What a lot of people don't realize is that solar thermal can be as much as 80% efficient, compared to PV at 20% on a good day. So environmentally speaking, solar PV requires 3 to 4 times as much solar panels than will ST, and the production of crystalline PV cells comes with a BIG environmental impact on the Earth. Even our government (DOE) is favoring PV. Follow the money... The recent tax credits will degrade for ST much faster than other environmentally harmful technologies. One part of the sham is that the performance of PV will degrade over time, whereas ST remains constant through the life of the solar collectors.
Even if you couple PV with an air source heat pump with a COP of 3 to 1 in an effort to boost its efficiency, it can't exceed ST.
Apologies for the rant...
ME
2 -
Jamie..........Connecticut or England?0
Connecticut. Where part of my family lives, though, in Scotland (Orkney) is worse...Paul48 said:Jamie..........Connecticut or England?
And on Mark's comment -- he is so right! Solar thermal really does work -- even here in cloudy Connecticut. Solar PV? Well, if you can afford the batteries...Br. Jamie, osb
Anything that requires a ton of maintenance (Heliostat) or is not yet safety-proofed-for-the-house (Solar Thermal) is a poor choice for residential and even small buildings. I have high hopes for fiber waveguides, bringing sunlight into hard-to-reach rooms and corners of the house. See, for example, this poorly designed website for some of the major players:
brightenyourhome.net/Hybrid-Solar-Lighting.html0 -
When PV panels get hot, and they do get hot, their output decreases. Keeping the panel cool with water makes sense. Someone needs to design a PV panel that can also produce hot water to be used for SH or DHW, either directly or through a heat pump.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
Several such designs (sometimes referred to as PV-Thermal or PV-T) have been produced during the past decade or so. None has really managed to gain traction, as the costs have been far higher than the market will bear.0
George is one of our steam customers. Welcome to the Wall, George!gbourozikas said:Anything that requires a ton of maintenance (Heliostat) or is not yet safety-proofed-for-the-house (Solar Thermal) is a poor choice for residential and even small buildings. I have high hopes for fiber waveguides, bringing sunlight into hard-to-reach rooms and corners of the house. See, for example, this poorly designed website for some of the major players:
brightenyourhome.net/Hybrid-Solar-Lighting.htmlAll Steamed Up, Inc.
Consulting0 -
The holy grail for solar thermal is the storage. It's expensive to try and store large quantities of thermal energy in tanks. The ground is an option.
Solar passive operation doesn't cost a penny, early cave dwellers knew how to take advantage of that concept.
You could consider ground source HP, in heat mode as solar driven energy converters. Drakes Landing, Weller School, and several others have proven using solar to preheat the ground, or injection wells leverages the HP efficiency.
For best solar heating look for the lowest possible temperature, heat emitters, Jaga radiators are a good example
One of the most efficient solar thermal DHW systems is at a bottling facility in Tempe AZ. They just pre-heat to around 100- 110, this drives the collector efficiency way up, and minimizes the gas boiler operation.
Un-glazed pool collectors will run mid 80% efficiencies when ambient and fluid temperature are close, very little loss to the surrounding air. Pool collectors still prove to be a viable business, look down the next time you fly into Florida.Bob "hot rod" Rohr
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
