steam boiler replacement
EzzyT
EzzyT Member Posts: 1,377
So this house is a 2 family which the home owner is turning it back to a single family.
We piped 2 new 11/4" steam riser for rooms that didnt have any radiators in them.
Ripped out the 2 neglected boilers and Installed a Peerless 63-04, 3" drop header, steam rated ball valves for the main, return and skim port. We also upgraded the main venting with 8- Gorton #2s.
Tight spot to work in since there is a wall to the left of the boiler and the steam mains and dry returns run along the main wood girdle beam.
Thanks Dave Labar for the referral.
E-Travis Mechanical LLC
Etravismechanical@gmail.com
201-887-8856
corydSWEIPaul S_3
  • SWEI
    SWEI Member Posts: 7,348
    Nice shoehorning job! Quite the Gorton farm you have going there -- it's somewhat difficult to tell from the photo, but I think I see some "interesting" angles there, and what may be drips at the other end of the horizontal runs?
  • EzzyT
    Yeah all the piping is in a super tight area.
    That's staining from the old main vents which weren't high enough off of the dry returns
    201-887-8856
  • SWEI
    I was wondering about the connections to both ends of the horizontal antler run.
  • ChrisJ
    ChrisJ Member Posts: 17,028
    edited January 2016
    Wow, that looked like fun.
  • EzzyT
    No leaks on our piping but once we got the boiler up and running we found 2 major leaks in the 2 separate steam mains, we fixed those leaks today.
    201-887-8856
  • Paul S_3
    Paul S_3 Member Posts: 1,291
    nice work ezzy....
    paul s
    ASM Mechanical Company
    Located in Staten Island NY
    347-692-4777
    ASMMECHANICALCORP@GMAIL.COM
    ASMHVACNYC.COM
    https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • EzzyT
    Thanks Paul
    201-887-8856
  • jonny88
    jonny88 Member Posts: 1,139
    EzzyT don't you love how much space they leave you for a mechanical room.Great work in a confined space.Good on you.
  • EzzyT
    You gotta love it and make it work.
    Thanks John
    201-887-8856
