steam boiler replacement
EzzyT
Member Posts: 1,295
So this house is a 2 family which the home owner is turning it back to a single family.
We piped 2 new 11/4" steam riser for rooms that didnt have any radiators in them.
Ripped out the 2 neglected boilers and Installed a Peerless 63-04, 3" drop header, steam rated ball valves for the main, return and skim port. We also upgraded the main venting with 8- Gorton #2s.
Tight spot to work in since there is a wall to the left of the boiler and the steam mains and dry returns run along the main wood girdle beam.
Thanks Dave Labar for the referral.
3
Nice shoehorning job! Quite the Gorton farm you have going there -- it's somewhat difficult to tell from the photo, but I think I see some "interesting" angles there, and what may be drips at the other end of the horizontal runs?0
Yeah all the piping is in a super tight area.
That's staining from the old main vents which weren't high enough off of the dry returns0 -
I was wondering about the connections to both ends of the horizontal antler run.0
Wow, that looked like fun.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
No leaks on our piping but once we got the boiler up and running we found 2 major leaks in the 2 separate steam mains, we fixed those leaks today.0
nice work ezzy....
paul sASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
EzzyT don't you love how much space they leave you for a mechanical room.Great work in a confined space.Good on you.0
You gotta love it and make it work.
Thanks John0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
