steam boiler replacement
EzzyT
Member Posts: 1,377
So this house is a 2 family which the home owner is turning it back to a single family.
We piped 2 new 11/4" steam riser for rooms that didnt have any radiators in them.
Ripped out the 2 neglected boilers and Installed a Peerless 63-04, 3" drop header, steam rated ball valves for the main, return and skim port. We also upgraded the main venting with 8- Gorton #2s.
Tight spot to work in since there is a wall to the left of the boiler and the steam mains and dry returns run along the main wood girdle beam.
Thanks Dave Labar for the referral.
3
Nice shoehorning job! Quite the Gorton farm you have going there -- it's somewhat difficult to tell from the photo, but I think I see some "interesting" angles there, and what may be drips at the other end of the horizontal runs?0
Yeah all the piping is in a super tight area.
That's staining from the old main vents which weren't high enough off of the dry returns0 -
I was wondering about the connections to both ends of the horizontal antler run.0
Wow, that looked like fun.
No leaks on our piping but once we got the boiler up and running we found 2 major leaks in the 2 separate steam mains, we fixed those leaks today.0
nice work ezzy....
paul sASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
EzzyT don't you love how much space they leave you for a mechanical room.Great work in a confined space.Good on you.0
You gotta love it and make it work.
Thanks John0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 15.6K Strictly Steam
- 49 Job Opportunities
