Only 2 months old
superdave
Member Posts: 155
HI All,
This is from a indirect 80 Gal. tank that is only two months old. What are your thought???
1
What's water chemistry like? i assume this is for DHW?0
Yeah......I'd be checking the piping for voltage0
Definitely get the water tested. The indirect manufacturer should have the recommended sacrificial rod for the results of the water test.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
You might want to put an electric anode rod in there. More money but it's only once.0
What was in there before?
How long did that last?
What has changed?0 -
I think it was 80 gal. before. Old tank was SS but the nipples was bad.
The house had water damage for last years snow old boiler went off line and some of the radiators cracked. So we added a zone of radiant and changed out 12 radiators to new Baxi radiators and new Baxi 40-GA boiler with 79gal. Baxi tank.
I know one wall was repaired by the gas and water meter then they installed spray foam insulation. I don't know if they removed the grounding wire.0 -
Sorry the boiler is Baxi 1.33 GA. with tank.0
Curious, how does a missing ground wire cause an anode rod to be attacked like this?
We have a water utility that treats with calcium carbonate we need aluminum anode rods or it turns hot water to seltzer waterLANGAN'S PLUMBING & HEATING LLC
732-751-1560
Sparkling water out of a faucet! How cool is that.0
Probably taste pretty good with the branch water.
3PSI gauge0 -
It depends on how things are set up -- but if a bonding wire is missing on a water pipe, current may flow through the water itself -- and the anode rod is an excellent place for that to happen. This eats the anode rod away (and puts the anode metal -- often magnesium -- into the water, by the way). If everything is bonded, then the electricity would much rather flow through the wires, being even lazier than steam.Br. Jamie, osb
