Pellet Stoves are amazing!
JohnNY
Member Posts: 3,336
What.
What's wrong?
What's wrong?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
1
One of the guys at work heats his house with a pellet stove. Runs electric baseboard when not at home. He likes it I think he said he went throug a bag every two days or so.0
Exactly.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
Lol if you think parts for mod cons are expensive, try part for a pellet stove.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
There are pellet boilers going in up here a lot nowadays. I don't have any interest in it.
I put in a fireplace insert a couple of years ago. I went into the store thinking I would install a pellet insert, but came out with a natural gas insert. The price of gas per BTU output of the insert was about the same as wood pellets!Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
A handful of my neighbors have replaced their wood stoves or inserts with pellet stoves. Most just got tired, or to old, for the wood burning ritual.
In my rural area the only fossil fuel option is LP and when it goes over 3 bucks a gallon the pellets are an attractive option.
Like all manufactured products there are good, better and best options. One neighbor bought a price point PRC import and has not had good luck with operation or parts availability.
Pellet boilers are a big market in Europe as the fuel is easier to store and purchase fuel in large quantities. Pellet boilers are much easier to "drive" and require less buffer storage to keep them running efficiently.
I'd be more interested in chip burners as the process for squeezing pellets is costly and energy intensive.Bob "hot rod" Rohr
The Austrians (among others) make condensing pellet boilers that are truly amazing. No interest in importing them here --we tried a few years back.
Bob is right, chips are a lot easier to source and have far less embedded energy in their footprint.0 -
After owning a pellet stove, if I was going for anything like it I'd be going for either wood or coal.
Too much crap to go wrong with a pellet stove and they are a bit pricey. At the time they were cheaper than oil, but a lot more than NG so once the new boiler was running I got rid of it.
That, and the guy that installed it thought it was a good idea to drive screws into the twist lock Duravent at every joint. And, the way it was installed didn't line up with the hole in the wall so it was leaking at the stove. It was a dusty disaster and fact is it didn't have to be had he simply followed the instructions like going up and then out the wall instead of trying to make the stove line up exactly with the hole in the wall. And of course, the screws...... that one really blew my mind.
But yeah, I'd be doing a typical wood stove and a class A vent. Even something like an older Fisher Papabear or even an Army Canon heater pot belly stove. My dad has a Fisher Babybear sitting around but I've really got no place for it.
While chips would be nice I don't see a real good feed system with odd size material. Pellets are consistent, and allow a nice dependable feed system to the burner.
Sometimes multiple pellet owners will go in together, and buy bulk semi loads.0 -
Some friends of ours have three first generation Quadra-Fire cordwood gasifier/stoves that have been in daily use for probably 25 winters at this point and still burn clean and hot. ISTR an EU engineering team (perhaps from Braun) being involved with the original design.0
@Fred nope not kidding it's a lot of work, but if you can heat your house and hot water for free other then the labor of cutting wood it's worth it in my mind. My parents went through 8 cords of wood last winter with theirs, but they also have a 3,000sq ft to heat and not very well insulated. I would probably go through half of that with only 1800sq ft and 40-50k heat loss0
Time is money too. I guess it's a trade off as long as you have a source for "free" wood but you also have to consider the other costs, like hauling it, cleaning, if/when the walls get smokey, carpets get tracked with dirt from hauling the wood into the house, cost of chimney/stovepipe cleaning and the work, OMG, the work
Cleaning isn't an issue for me either growing up my dad way a chimney sweep ran his own business for a long time. I would help out on the weekends if need be and if I was off from work.
Time is money you have me on that one, but I enjoy being out side cutting and chopping wood. It's relaxing to me and a time where I can turn my brain off and do mindless work.
I go through about 2-3 cords of wood a year now in the fireplace and out side fire pit. Although this winter has really been all that cold I haven't even had a fire yet.
Yes I get free wood from a buddy of mine.
I used 630 therms of gas for hot water, heat, and cooking in about 14 months time period about $800-850 for NG. A cord of wood goes for about $200 by us.0 -
I was always lead to believe if you operate a wood stove correctly, that you'd rarely need to clean the pipe.
Not sure if it's true or not, but that's what I've always been told.
What I can say is if you operate a NG burner correctly you rarely need to clean the pipe.
I enough my dusty forced heat pump/ hydroair system. I get long run times with low cfms with 100-105 supply air temps. I'm sure it's not as good as a constant circulation system with panel rads and trvs. But one day I will get there.0
Solid fuel heating is a hobby as anything. Many of the wood burners quit the fuel once the fun goes away.
Still other rationalize the fuel for the physical exercise it provides. And it is a renewable energy source, in some areas the fuel is free for the taking.
If you visit some of the chat rooms many are obsessed with the wood and pellet technology, just as we hydronic junkies are.
Pellets just make it a more viable fuel for the average homeowner.
I don't see a pellet heater of boiler being more complicated or expensive to repair than a mod con?
Living the hydronic dream1 -
A number of moving parts exposed to high temps -- more likely to require regular cleaning and care. Here's an animation of the KWB design we were tying to import.hot rod said:I don't see a pellet heater or boiler being more complicated or expensive to repair than a mod con?
I served as the Pacific N.W. tech support for Quadrafire for all of last winter (my first foray into that market......was like a bad dream but I learned a lot). Were I to have an application for a pellet stove, I would ONLY buy the QF CB1200. If maintenance is performed as it should be, very reliable and puts out a nice clean scorched air, and even a little bit of radiant. Inserts? Not pellet inserts........no way! The FS models are hard enough to get in and work on! Pellet fuel is where the lions share of bad issues originate......inconsistent from bag to bag not to mention from beginning of season to end of season. Premium Fuel (Olympus in our area) is your only defense against middle of the night frustration. Also.....when it comes to NG or LP on stoves and fireplaces.......the new electronic ignition units are a PITA compared to old reliable thermocouple and thermopile technology. Glad to be out of the retail side of things this year.....hope I never have to do that again. Absolutely amazes me how rude people are when you are just there to help them. "come and take this hunk of crap you sold me and shove it!!!" was a typical morning, afternoon and evening phone call. A lot of angry not nice people out there. I remember leaving work many times thinking "humanity is doomed".
Race to the bottom Don.0
Building our place upcountry this spring and am toying with going with a Greenwood indoor wood boiler. Would put either electric or propane as a back up system.
Big problem right now though is being a Canuck, our dollar is diving quick.
And JohnNY, don't feel bad, I have never had hydronic heat either. Right now living with electric baseboard and fan assisted wood burning fireplace.
By the by, guys up country with wood boilers, if they don't want to do the whole tree dropping/limbing/etc. thing, buy a logging truck load of wood. Already limbed, etc. About 17 cords @ 70/cord.0 -
Bottom line with any pellet/wood appliance in the scorched air concept. Solid fuel just adds to the dust and the temperature of the air making it worse with ductwork and fans. I own and operate a gasification boiler and am happy to say that wood and hydronic radiant work very well together. My boiler room is very clean and I can walk in there with my socks on and not worry about getting them dirty. An entire season of wood is stored in there as well as the boiler.
We in the northeast do not have the option of NG yet and most still burn oil. With oil as the standard pretty much any other fuel other than electric resistance are quite cost effective.
The downside of any system that is not completely automated is that there is "the user factor" meaning not only the quality of fuel, but also the operator and how adept they are at actually running the system. Just like all the "de-knuckle-heading" on steam there is much of that in wood heating.
If one is truly interested in it, it is the least expensive option for many people who do not have NG, and the independence of not being tied to a supplier for fuel is an attractive selling point as well.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
@Solid_Fuel_Man
Just out of curiosity how much wood do you go through a season?
How many square feet are you heating?
Which boiler do you?0 -
3,200 sq feet heated space. 3 full cord last winter, that includes 100% of DHW during the heating season via 119gal heat-flo indirect. No other heat sources used. 9560 heating degree days average.njtommy said:@Solid_Fuel_Man
Attack DPX45
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!2 -
To be fair it's all hard maple and yellow/white burch.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Need to get some hedge. Burns near white hot0
Don't forget the exercise component, (keeping us all young), bring in the fuel, and take out the ashes!
When we burned coal in our old steam boiler, the clinkers were a wheelbarrow a day, run up planks on the basement steps, and out behind the barn!
Most likely it's the same with the pellets, in smaller amounts.
It's just like indoor toilets before the piping was put in.--NBC0 -
My parents go through roughly 3 cords a winter in their fireplace. In addition to that they burn about 300 gallons of oil in the furnace. 2500 sq ft house. The fireplace isn't efficient by any means, but my mother loves the romance. The basement staying at around 75°-78° all winter is a bonus. Wood is still fairly cheap where they live, cheap enough it saves them during the winter. My dad is 70 and still moves and stacks it all himself. As NBC said, keeps them young. I actually just bought him a wheeled cart for bringing the wood into the house, before that he was carrying it all. When I lived there that was one of my chores, after I moved out they stopped using the upstairs fireplace. I guess they didn't want to carry it up all those stairs. lol0
My folks do it as well... wood burning insert in the living room (mostly heats it and the kitchen) as supplemental heat. Dad says he'd easily burn $2500 in oil over the winter when it was ~3/gal here in CT. House is two stories, ~3000 sq ft, but only the first floor is conditioned.
They go thru about 2-3 cords a winter. Dad says it saves him quite a bit on oil, gets the wood for free and splits it in his "free" time. Still finds time to be bored, go on vacation, play guitar, etc... i.e., splitting wood doesn't take that much time/work. Mind you he's 60 and still works 8-5 fixing cars.
Otherwise no real maintenance, they've had the Jotul insert for ~15 years and just replaced the chimney insert so it goes the full 2 stories vs. 1 story (all that was required back when it was installed).0 -
So what are pellets going for a bag? Was at menards, and 3.99 a bag on sale. Bag said 8000 btu per bag? Per #? That's expensive no?0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
