Steam boiler replacement coming up
Dave0176
Member Posts: 1,178
Got a call from a fellow in Garwood NJ complaining of having to fill his boiler up every day. I told him to look at his chimney and see if nice white plumes of steam are billowing from it. He called back and confirmed yes. Unfortunately the boiler is rotted, not sure why, it was installed in 1997 albeit very poor piping "copper riser" minimal main venting, a slight bit oversize. Its a Burnham IN5 which puts out 358 sq ft steam, system measured at 317 sq ft of connected load. He purchased the home not long ago so I'm assuming at one point possibly a radiator or two was leaking. The Home owner replaced all the vents not loong ago sooooo.
Anyway we will be installing a Weil McLain EG-40 which is a bit closer match to his EDR.
And yes the Home owner is an avid reader of DHs LAOSH......!!!!!
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Who's Lost Art book is that on the boiler? Can't wait to see the new one!0
KC it isn't mine, mine is barely legible and doesn't even resemble a book anymore lol.............. Time for a new copy.KC_Jones said:Who's Lost Art book is that on the boiler? Can't wait to see the new one!
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
Replacement completed.
I cannot force people to spend money, I can only suggest how to spend it wisely.......3 -
Very Nice! Does the water supply there have high chlorides?Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Nice, what an improvement!
Can I get the part # for that? ; )
Steve0 -
Looks Great!!0
Thanks Steve, here's the part number $$$$.00. Lolsrmaietta said:Nice, what an improvement!
SteveDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......2 -
Great, professional job. Your client should know the elevated workmanship they've gotten with this installation.
Now maybe we can get one or two guys on here to take pot shots at it for using tees they don't like.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
