venting issues standard 80% BOILER and standard water heater natural vent b vent up thru roof
Bob C._2
Member Posts: 31
not getting good draft- flames lazy n water heater- boiler has sooted up=natural gas-chimney pipe is corroded badly
has been replaced runs up thru knee wall and up thru attic shows signs of condensation gas pressure incoming 6"
thought?
thought?
If you open up a door or window to the outside does it look any better?Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge0 -
Step 1 -- go out and get a reliable CO monitor and put it near the boiler and water heater!
Step 2 -- I second what @BobC. said -- is there enough air getting in to allow the units to draught? Is the building tight, and is there an exhaust fan somewhere (kitchen, bath)?Br. Jamie, osb
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
