Room by Room vs. Total Structure heat loss question
jb9
Member Posts: 104
I have a question about the relationship between a heat loss calculation for a structure versus a room-by-room heat loss calculation. How do the two relate if placed side by side? I have done a heat loss calculation for my structure, but in order to proceed with how I want to design my system, I need to do a room-by-room... I am sort of stuck. How do I treat the interior walls in my calculation? If someone could provide a simple example, that might help. I did all my structure calculations long hand, so I am not intimidated by the math. Hope this isn't too rudimentary of a question to ask... Thanks in advance.
They are "warm partitions", kind of a non-issue save for their value in determining room size.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
The relationship should be the same as far as total heat loss.
The difference is each room will have different loads depending on outside wall exposure ( 1 side, two sides, and three sides exposed), orientation,glazing and solar influence.
There is cold partitions also. Such as a room next to a unconditioned space. Usually a wall between an attatched garage.0 -
Simple if you want to do them.
How to find heat loss through a panel
(Ti-To)/R-Value = Bthu/hr per sqft
Ti = Design Temp Inside the panel room
To = Design Temp Outside the panel room
R-Value = R-Value of the Panel
(70-0)/19 = 3.68 btu/hr per sqft of panel
This is just the loss through the panel.There was an error rendering this rich post.
- 121 Chimneys & Flues
- 15.8K Strictly Steam
