Saving a Burnham IN-9 at the Historic Warnebold House
Dave in QCA
Member Posts: 1,806
About a year ago, friends purchased a great old home in Davenport, IA. It was built in 1881 and has 98% of the original pipe tube radiators. It is piped up in a 2-pipe Vented arrangement, knuckleheaded to no end, but that is a subject for a later post.
This post will deal with the boiler that the previous homeowner installed a few months before the sale. As is usually the case, the installer meant well, but missed the mark entirely; not even a Hartford loop. How many ways is the boiler piped wrong? Can you count the ways?
Dave in Quad Cities, America
http://grandviewdavenport.com
Ben to the Rescue!!
Friend and great steam fitter, Ben, of J. L. Brady, Co. arrived on Tuesday to repipe the boiler the way it should be. Note the great drop header! It should produce excellent dry steam. While he was at it, he installed the proper skim port, separated the building mains that were stilled combined by leftover piping from a previous boiler.
Now.... time to focus on repiping the returns, drips, and correcting the venting.
Another Great Job Ben!Dave in Quad Cities, America
http://grandviewdavenport.com1 -
Very nice!!DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
Looking good- can't wait to see the rest of the system!All Steamed Up, Inc.
Consulting1 -
