l8148j aquastat
pjc9906
Member Posts: 2
in Gas Heating
i just replaced my l8148j aquastat. everything is running fine but the burner wont shut off. were did i go wrong
Then it's not running fine. Either the new control is bad, or it's wired wrong.
Here's a wiring diagram. Look for the 8148J and see how it matches up.
Note the part in the notes about jumper selection.
http://www.republicsupplyco.com/SpecSheets/60-2278.pdf
How did you determine you needed to replace it. Maybe something shorted it out, and now the same short is affecting your new one
Do you have a 24 volt gas valve or a powerpile self generating valve?
If you have a 24 volt valve wire valve to B1 and B3 and insert jumper between TP and Z.
If you have a powerpile valve wire B1 and B2 to powerpile valve and no jumper between TP and Z.
Give us the number of the gas valve and the make?0
