Fill Valve
That's a 30 psi fill valve.
- DF0 -
It'sa pressure activated bypass with backflow prevention dontchaknow.... :-) Hi Dan.
Hat, technically speaking it IS a PRV... Different meanings to different peeps. Which is why I avoid the use of those particular initials. Too many potential meanings...
I once saw a picture of the relief valve discharge piped into the expansion tank.
#equallydope0 -
I have seen several pressure relief valves for boilers and water heaters piped into a pipe PLUG. (I'm sure others have also witnessed this......"damn cheap valve/fitting that leaks, we will fix this.....see no more dripping!!")0
Brilliant! WTH!?!LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
I also like the mess of pipe dope, some smeared on the side of the valve etc.Harvey Ramer said:Those solder joints... Like snot running out of a kid's nose on a cold winter day.
Whoever did this work should go take a nap or something.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Good news is the system will be full . Bad news is the system will be full . LMFAOYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Shame just as many HW systems are being messed up by "knuckleheads" as steam.Rich said:Good news is the system will be full . Bad news is the system will be full . LMFAO
This is what happens when your counterman is smarter than you or you count on him telling you what you need . Another option is , You're just STUPIDYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Not knowing how to work on a boiler doesn't make a person stupid any more than knowing how to work on one makes a person smart.Rich said:This is what happens when your counterman is smarter than you or you count on him telling you what you need . Another option is , You're just STUPID
It just means they had no business working on the boiler.
Putting a pressure relief valve on a boiler thinking it is a pressure reducing valve and working on a boiler knowing that you have no clue are both STUPID .
Let's not mince words here or give PC lessons Chris , I do not require such . If that was not your goal I apologize but the attempt at political correctness and coddling idiots has never , will never work . My only hope is that the fool that did this comes across this thread .
Maybe I only speak for myself but I learned much more being told I was a **** than when someone told me I was a good boy and don't do that again . Just like many creatures learn from pain , if it don't hurt , lessons usually are not learned .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
No, I wasn't giving PC lessons, I was being realistic Rich.Rich said:Putting a pressure relief valve on a boiler thinking it is a pressure reducing valve and working on a boiler knowing that you have no clue are both STUPID .
Giving you lessons on PC would be the definition of futile.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment3 -
I guess that would depend on one's definition of realistic . Our country for instance has become quite PC , now look at all the worries we have from all angles . Oh well . Politically correct should have been left in the laps of politicians and not society . It is PC that makes politicians , politicians after all . Guess we are all just full of crap now and as bad as them . Futile would be an accurate word .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
I agree that installer is stupid....Pretty much page one or two of all boiler manuals says IMPROPER installation can cause death....Jesus if that's not making it clear enough that you need to read and follow the manual I don't know what else is....Oh dear Mr. Handy man, please stick to fixing door knobs0
http://armyphotos.togetherweserved.com/439595.jpg
I know, I saw it right away too....
No safety glasses or hearing protection.
And I caught something else that is really important~ He has no gloves on.
2 -
orBob "hot rod" Rohr
He did make a nice clean transition with the 3/4 X 1/2 c-male adapter. That took some forethought.Bob "hot rod" Rohr
You have to kinda wonder, if when this guy was putting this togather. Was he thinking that the manufacturer is so stupid for not making a pressure reducing valve that pipes straight through instead of at a right angle.
If you have to question why it seams like things are going togather hard. It's probably not going togather right.0 -
Please tell me wasn't a plumber..who installed that...And it was just some kind of wannabe plumber.....0
Bet it was an actual plumber.j a said:Please tell me wasn't a plumber..who installed that...And it was just some kind of wannabe plumber.....
Probably licensed in Massachusetts.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
Yup I think so , but came from the New York New Jersey area where he got all his training..figured he would come up here and show us what we have been doing so wrong for so many years...I hear he is leaving soon, heading to JAIL...lol0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
