triangle tube prestige solo 110 boiler
john_117
Member Posts: 15
We have replaced the draft inducers twice in the last 9 years for this boiler. The inducer has fallen apart on both.
anybody see this before?
sorry the inducer wheel has fallen apart0
You mean like this? Solo 175 day before Thanksgiving. What Robert said, or a fluke. Not common.0
Does your system cycle on and off a lot?0
Lets see a picture(s) of the outside where your vent and intake terminate....0
No pix?
We would love to help...
kcopp0 -
Mine did the same after 4 years ,just blew apart today , however it does cycle often due to how it is hooked up to a brazed plate hot water heater for domestic and a flow switch , sooooooooooo, i will make changes on my end but TT should use SS for the inducer wouldyathink???0
TT boasts about their SS , all of it . the plastic one is more like a sugar wafer , what a piece of #^#^^. for a 3700 $ heater , i disagree with the cost benifits . they even sell the repair kit with a briefcase omg. for 1700 $ with more plastic . so until they improve i will not install anymore solos , just soyano.0
If the venting is correct you usually don't have a problem. I have solos out there that are 5+ years old without a single issue. I never use a concentric vent no matter what. I would rather use indoor combustion air before a concentric I just don't trust them.
2
