Best Boiler Stop-Leak (Boiler Leak Sealer)
MrVince
Member Posts: 25
Happy Thanksgiving, everyone.
I've got a boiler that needs some attention. There seems to be a small leak coming from one of the sections. But, with contractors' hectic schedules right now, we'll need to replace it in the spring or at least 2 months from now.
Can you guys, recommend the best boiler sealer?
There seems to be several products on the market:
- Hercules Boiler Stop Leak
- Gunk's Liquid Boiler Sealer
- Black Sawn's Boiler Stop Leak
- Safe's Silver King
- Hydro-Seal Boiler Stop Leak
- Utility's Boiler Weld
Which products have you, guys used and how were the results? Each of these products come in liquid or powder form. Did you find that the powder form was more effective?
By the way, this forum is a great place for people to help each other. Thanks for the help!
Vince
Vince
Can you describe the nature of the leak? Is it a pinhole in the metal, or perhaps a bad gasket between the sections?
My experience with stop leak shows it can slow a leak down, but probably not stop it. If you had a hot water system, you would have better luck in stopping this. Some of the products are so smelly as to drive the occupants out of the building for a couple of days.
Make sure your pressure is reduced to mere ounces, with generous main venting, so as not to put any pressure on the leak.
You probably only have a couple of weeks before this lets go, so plan on the replacement now, by figuring out the total size of your radiators (EDR), so the new boiler can be sized right.--NBC0 -
And two other thoughts -- if the leak is above the water line, there is no stop leak product that is going to work at all...
And I've yet to see a leak which got smaller with time.Br. Jamie, osb
Nicholas and Jamie, thanks for the heads up.
The leak is luckily below the water line. It might be from a bad gasket but I can't be sure until the sections are taken apart.
Have you, guys tried out a few of these products and if so, any that you particularly recommend that works better than the others? Any preference on liquid or powder?
And, how long do these sealers typically last for you, guys? It's particularly cold where I am and to get my guy to even come out and price out the replacement was an ordeal. So, I'm hoping that the sealer will last for at least 2 months so I can do the replacement the right way. I don't want guys to do a half **** job.
Thanks for the advice. And, Happy Thanksgiving!
Is it a seep, or dribble leak, as far as volume goes?
I am sure they are all the same sort of chemistry, so prepare the occupants for some smells, (we used the gunk product, I believe).--NBC0 -
Hair pine crack in under water level in gas water heater Burnham all origin0
Sorry what’s best product to deal pipe can stop leak use heat. Any help I can get. Was thinking muffler weld0
Used Hercules posdibilly incorrectly wasn’t hot when used. Worked shortly0
Have used Hercules and the Gunk brands. Both have worked well. It can buy you a few months threw winter till the warm weather arrives again.
Be sure to follow the directions carefully. If you don't, you can fill the hole that is leaking but also fill a port in the boiler that needs to read water level or pressure etc.
The Hercules is a bit more forgiving if you use a little more than required. I have used both for residential and commercial temporary boiler repairs.
Do not trust these products to be a permanent fix. Treat it like a temporary fix until the leak can be corrected properly.1
- 120 Geothermal
