Fresh air piping, high efficiency furnace
newmark
Member Posts: 1
in Gas Heating
I'm having a 96% efficient Carrier Furnace installed in a house being built. The installer installed the expected PVC piping for the exhaust. However, he only installed a 3 ft. PVC pipe on the intake port of the furnace. It rises up 2 ft from the intake port then makes a 180 degree turn down and stops. Is it correct to only take in air into the furnace from inside the house?
As unclejohn says, yes it's allowed -- but it is very poor practice, particularly in tight houses as many new ones are. You need an outside direct fresh air intake.Br. Jamie, osb
