Which one is better? Forced hot water he sealed combustion or Forced hot water he natural draft
nypoyu
nypoyu Member Posts: 2
Dear All:
I try to change from oil system to gas system in my house in long island, NY.
National grid gave us a list to choice the boiler for rebate. Right now I am choosing between forced hot water he sealed combustion or forced hot water he natural draft from two plumbers. Please give me some suggestion for two. Good thing and bad thing. Which one is better?
My house is split type house with around 2000 sqf area including garage.
Any suggestion is welcome.
Thank you,
  • What is the present system-hot water, or steam?
    If you have steam now, there can be problems with a conversion, such as leaks.
    If you have hot water, you can have a "mod-con" boiler, which is more expensive, but has some valuable advantages, such as using outside air for combustion, and outdoor reset, which varies the loop temperature as the outside temperature changes.
    These boilers must be installed, and maintained ongoing, by a very qualified hydronics specialist, who may or may not be a plumber. Don't bother to read many online reviews of the various makes, as the horror stories are mostly to do with improper installation by an untrained moonlighter.
    A heat loss survey of the building must be performed, in order to size the new boiler, and not merely rely on the rating plate of the old boiler, or you will not get the maximum efficiency and savings.--NBC
  • nypoyu
    Hi nicholas bonham-carter: Thank your info! I have hot water system for the house. What is "mod-con" boiler? Is it in the National grid rebate list? How do feel Forced hot water he sealed combustion and Forced hot water he natural draft? Thank you!
  • Rich_49
    Rich_49 Member Posts: 2,785
    Could you post a link to the National Grid list and the program rules nypoyu ?
    732-751-1560
    Rich McGrath 732-581-3833
  • jumper
    jumper Member Posts: 2,530
    less to go wrong with atmospheric burner.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,589
    Nat Grid program is Burnham products only...at least until 12/31
  • Rich_49
    Robert , What type of program is this that Natl Grid is offering or participating in ? Are you saying that a program which uses ratepayer funded monies has an exclusive deal with a manufacturer ?
    732-751-1560
