Improvise
When all else fails
jonny88
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,012
    Who knew Makita made pumps?! :o
    Yours, Larry
    Jamie Hall Member Posts: 26,850
    Love it! Did you get that from Amazon? Seems you can get pretty much anything there...
  • kcopp
    kcopp Member Posts: 4,630
    Red Green would be so proud!
  • rick in Alaska
    rick in Alaska Member Posts: 1,514
    Check out the website thereifixedit.com
    It is full of stuff like that. Mostly shake your head kind of stuff, but some good ones. Good for wasting time on the internet though.
    Rick
  • ChrisJ
    ChrisJ Member Posts: 17,074
    edited November 2015
    Would've been better if most of the vent holes on the drill were open and it wasn't taped to something combustible. Looks like 90% of the vents on the drill are blocked.
  • SWEI
    SWEI Member Posts: 7,348
    I've had one of those drills for 25 years and I'm starting to believe it may actually be indestructible.
  • ChrisJ
    I worked for Bosch as a repair mechanic and I repaired many manytools guys thought were indestructible. ;)
